When I try to engrave a very simple text job I get a “Not enough extend space” error. However, if I change settings from Fill to Line it works. Has anyone else had this problem? I don’t see why it would engrave the outline without a problem but not be able to fill the shape?
As Barrie mentioned, it is the automatic overscan setting. The laser head will travel past the extents of your drawing by a variable amount based on the speed to allow the head to accelerate/deccelerate to and from the desired engraving speed before firing the laser. This gives a better quality engraving than if it tried to engrave while still changing speed.
