I recently updated from LightBurn 1.7 to 2.1.04. Everything initially worked, and I successfully engraved a project with my Gweike laser.
After that, I opened another file I had successfully used before. The laser moved to the correct starting position but then just sat there and never fired. There were no errors or warnings.
Since then, I’ve also had strange behavior such as very slow movement, unexpected homing, and the laser moving to the wrong starting location. I went back to LightBurn 1.7 and noticed some of my settings had changed, including speeds showing around 30,000. Correcting the speed and power manually did not fix the problem.
Gweike support tested the laser with different software, and it works normally and fires correctly. I also tested my ComMarker with LightBurn and am now having problems with that laser as well.
So I have two different lasers that appear to work normally, but neither is operating correctly through LightBurn.
Has anyone experienced this after updating to 2.1.04, or know what settings/configuration I should check?
