Not fluent movement while using Ramp Length and Ramp Outer Edge
Hello, I have a problem while egraving with Ramp setting enabled, the problem is that CO2 laser slowes down to nearly minimum speed over surface that should not be engraved, I don’t know what can cause this issue…
My setup:
[PRODUCER:MKS DLC32]
[V2.30(8M.H35.20231206)]
[VER:1.1h.2023120602:]
[OPT:VMPH,63,512]
Target buffer size found
[MSG:Using machine:MKS DLC32]
[MSG:No Wifi]
The problem I’m talking about:
Can’t send the video…
Maybe it slowes down because its thinking, that it has to stop to 0 to execute next command and that’s the issue. It should go at the same speed, o matter what power has been set…
Here’s the GCode:
testRamp.gc (1,3 MB)
Can you post your project file?
