The power setting is two values, Min Power and Max Power. When cutting slowly, depending on your controller firmware settings, it’s possible that it’s only using the Min Power value. You haven’t said what the Min setting is in either LightBurn or RDWorks. You’d need to set both in each software for the comparison to be meaningful.
