Hi,
I find it hard to rotate a shape numerically. i can only see the angle during rotation in the lower left corner of the ui and if i release the handle i can’t see where can i enter numeric value for the angle. it took me few tries to fix it on exactly 30.0 deg using only mouse / cursor moves.
There’s always this one:
And if you hold the Ctrl key while drag-rotating, it snaps to 5 degree increments.
Thx, this rotate numeric input shows 0.0 even after rotating so i thought it was not related as i was after absolute positioning rather then relative.
It shows zero once the object is rotated because of the way the information is stored. It’s always relative to the current rotation.
