I created an image with a few objects and some text and carefully spaced them out but found when I engraved the project text and other objects were touching where as in LightBurn they show to be spaced apart. using the latest version and have not experienced this before and have been using Lightburn for sometime. Just wondering is anyone else has had this happen and if it’s a bug in the latest version.
Not so far. Show us what you see and provide some details and your LBRN file if you are willing. Screenshots and cut settings for the job would be helpful as well, and we can go from there.
Thanks Rick I found it unusual as Lightburn has been spot on every other time
MJ & Kobe - Mirror.lbrn (1.1 MB)
The result has some of the text moved over touching the other objects
When I did this on the mirror the mirror is securely held in place by a jig and the engraving speeds are pretty slow so no movement by the mirror
