Odd behavior during a fill operation
I have a Thunderlaser Nova 63 and have been having some issues with the Y axis intermittently not moving toward the back of the machine. Yesterday we confirmed the x and y limit switches were both operational and then decided to swap our two X/Y Device drivers (CL1-507-3LS). Later we observed something that makes it seem like the issue may have followed the Y-driver. This issue occurred while engraving names into wood. The engraving process would begin normally and progress through a portion of the job. At some point during the run, the X-axis stopped moving entirely while the laser continued firing. The Y-axis continued moving as though the controller was still processing the file, but no X-axis movement occurred. This resulted in the laser firing repeatedly along a single vertical line while the Y-axis advanced.
Anyone ever heard of something like that?
Check the connections between the control board and the motor driver, and the motor driver to the stepper. If any of those wires are loose in the plug blocks, it could easily cause this.
It certainly seems like the stepper driver is failing, but check for a few other things first.
If the driver matches that picture, then the (possibly mislabed) LEDs should indicate it has power (typically green = on) and no error (typically red = off).
If the error LED lights up, then it may be blinking an error code. Per a previous discussion involving that driver, searches for a manual seem unavailing, but that’s the only way to know what’s going on.
We’ve seen a few instances of defective / intermittent connectors between the Ruida controller and the stepper driver, including one where the entire metallic guts of the screw terminal was missing. That seems unlikely, because the problem follows the driver, but verify the terminals inside the driver block look OK and, while you’re at it, that all the wires are securely fastened in their terminals.
Because this started with the Y driver & motor, which are fixed to the frame with no moving wires, it’s unlikely to be a broken wire in the cable. Similarly, a motor or encoder problem would not follow the driver swap.
Take a look at the driver to see if it’s telling you anything … :grin:
