Odd Engraving issue
Hey folks
Wanted to ask a question, has anyone encountered an issue when doing a fill on metal where it engraves just fine and then using the same metal piece, same settings it fails to engrave into the metal? I encountered this last night and I have been researching the issue but failing to locate any resources. What i do know is
Same piece of metal
  1. text engraving works fine, engraves to proper depth, however when I change a letter or number in the text and hit the run button it no longer engraves into the metal as a fill its more like I chose line but its set to fill, no settings have been changed.
    Anyone encountered something like this or is it just me?
Does the preview look OK?
You should always run it through the preview to ensure it’s doing what you want. This is where I’d start…
However, you’ve give us nothing to help you with. Settings and lens length would help along with a couple of photos of the attempts, would sure help us help you.
:grinning_cat:
Thanks for responding, forgot to mention preview looks good for both, the settings do not change only the text (changing from an A to a B). the A fills just fine correct depth and such the B is not filling just lining on the top. I went through the settings twice last night and they are exactly the same, this is a very odd issue
Monport GM60W Mopa laser with autofocus
Settings without screenshot
Speed - 1000.00
Power - 75.0
Mode Fill
Freq - 25.00
Q-pulse Width - 200
Global Passes - 5
Bi directional fill - on
Cross-hatch - on
Line interval - 0.0250
Lines per inch - 1016.00
Scan angle - 45
Number of passes - 5
Angle increment 0.0
These are the settings i currently have set
When you get a chance, upload the victim so we can see what it’s doing. It’s very hard in any language to discuss technical issue like this withou seeing what you’re getting and how it’s set up.
  • lens length
  • settings power, speed, q-pulse width, frequency and interval.
  • photo
:grinning_cat:
What kind of metal and how physically large is it?
What lens are you using?
:grinning_cat:
Thanks Jack
Ill upload when i get home
