This is almost certainly a user config problem:
JTech laser mounted to XCarve. I have a fixture mounted roughly in the centre of the machine bed that holds round workpieces. They aren’t coasters… but let’s call them coasters to keep things simple.
So what I want is the work origin in the centre of the fixture.
Machine is set up with home left front (positive coordinates) per XCarve default. Homing machine correctly executes homing cycle. Jogging works as expected.
Jog laser over to fixture and use “Laser Fire” to align laser with the centre of the fixture. Select “set user origin”. My expectation is that I have now set “work zero” the same way one does in a usual CNC context.
Down in the lower right part of the screen, set user origin to centre. Draw a circle around it, set cutting parameters. Set origin to “current position”, press Run, laser cuts a circle in the correct spot.
Set origin back to “user origin”, press Run, machine rapids hard left and forward.
Re-home machine. Jog back to the fixture centre, press “set user origin”, then go to “get position” from the move tab, and instead of it being “0, 0” as expected, it is something like “-10, -8”.
Which is deeply weird, because the machine definition definitely is positive coordinates.
My expectation is that I should be able to power up, home, jog to a location, set user origin, power off, power on, home, then select “go to zero” and the machine will move the the zero set earlier - because that’s what happens in a CNC context.
What am I missing?
