Offset bed settings
I’m running a laser on an ender 3 (i know its not the best but was cheapest way to start before investing money) the laser is 50mm off of where the nozzle is and therefore 50mm off set on the bed center. Is there a way to tell light burn to add 50mm to the Y axis? I tried changing the home offset but printer says its too far. TIA
I have done this in my firmware using the M206 command. Have you tried that?
What is exactly the message from the printer? It might be that you have to put them in a negative value, but that depends on your coordinate system.
