Offset Fill Hanging after Certain Percentage
Hey All… Fairly new to Lightburn, and in looking through the past posts, I see a lot of references to Offset Fill hanging on complex designs with older versions. I just downloaded the latest and am seeing it as well, so am curious if this is still an issue, and really not much that I can do to work around it save a less complex image.
Thanks in advance…
Welcome and thank you for this post. Please share an example file where you experience this behavior. We can take a closer look. :slight_smile:
Sure… is there a direct place to upload it?
Sure, you can load it here. You can drag and drop directly into a reply or use the upload button, found in the reply tools.image :slight_smile:
