Offset Fill Laser sometimes not firing
I have been doing an engrave & cut on MDF, the engrave part is multiple engraving areas. If I do this using Offset Fill some of the engravings start then part way through the laser stops firing, once it moves to a new area it will start firing and will be OK. If I do the same file using standard fill it will all work OK, and all the engravings are fully done. I have never had this before using Offset Fill, the file is one I purchased and there appears to be nothing wrong with it. I have checked all electrical connections and even swapped back to my original Laser unit and it does the same with that one. Any ideas?
Show and Tell time.
Show us your Preview
Show us your Results
Show us you settings under Cuts/layers window
Upload an example of a file that does this bad behavior, then we can try to duplicate it on our machines.
