Offset Fill, Missing Spots, DSP
Is there a way to correct the “missed spots” when engraving using Offset Fill if I don’t have the overscanning setting?
Those little “tick” marks in the lower left corner were missed during engraving. The artwork is solid, if I do fill engraving everything is fine. I have a lot of brass tags to engraving. Being able to use Offset Fill will save me A LOT of time.
For that simple shapes you can offset and repeat the outer shapes inward with a distance equal or slightly lower than your spot size.
It’s almost the same without the voids.
The simple shape shown above was just for playing around with Offset Fill settings on a piece of black aluminum. The actual engraving is 5mm text on brass. The text, depending on the letter or number, has numerous missed spots.
For the large brass plates I am doing, if I do plain 'ole fill engraving, dark on brass, it takes about 35 minutes. If I do the same engraving but use Offsett Fill, they take about 4 minutes to engrave. I will have 40 plates that need to be done. These are regular orders and completely different text from order to order.
So I would really benefit from getting this Offset Fill to work without missing spots.
Increase LPI to reduce the gaps in your letters or soften the focus to enlarge the laser spot to fill in small gaps at the same LPI.
-or-
Have you explored using FLOOD FILL?
If you study Offset Fill (I think OZ explained it in a posting somewhere), you will understand why those artifacts occur.
Check all 3 FILL modes. I have had occasions where Offset took longer than Fill.
I’ve tried all the fill modes, offset fill is the quickest at 4 minutes. The next quickest is the flood fill at just under 13 minutes.
I understand why offset fill is missing spots, at the start-stop and random areas in the text. I was just hoping that there was a way to fix it so that function is actually usable.
Soften your focus to get a wider spot
-or-
Make your lines closer together to close those gaps.
-OR-
Do both at the same time for double the fun.
If you crank the power up and cook the bajeebies out of it, you will not notice the artifacts.
I have actually taken advantage of the Offset Fill creating a pattern on some projects. It gives it that unique look.
If you are making text engravings, I have found that sans serif fonts work much better as they are generally constant width, and OFFSET fill builds a more solid structure with those. The more frills, serifs and fancy pants stuff means more computational hoops for the laser path.
+1 to the occasional use of OFFSET fill to obtain the patchwork artifacts on purpose. The preview button is my most often used command other than CTRL+Z :face_with_crossed_out_eyes:
