Offset Fill - Pen Tool Issue - line connecting shapes
I am using LB with a pen tool - laser power value set to control the servo motor UP/DOWN. The outlines and linear fills work as expected.
I really like the offset fill option, but at the end of each shape the pen does not return in the UP position, thus connecting separate shapes with a line.
I manages to fix this in the Line mode by setting the Advanced>Power%=0, and the linear fill does this automatically at the end of each line. However the Offset Fill does not have any options to address this.
Is there anything I am missing here?
This would be an amazing feature when using the Pen tool.
Perhaps you’re one of the very few people using LightBurn who should set GRBL parameter $32=0 to disable Laser Mode.
That’s a good point, but laser mode is already disabled.
I am using an OpenBuilds ACRO system, firmware is tweaked for pen use.
Here is a snapshot for anyone interested:
$0=10 ; Step pulse time, microseconds
$1=255 ; Step idle delay, milliseconds
$2=0 ; Step pulse invert, mask
$3=0 ; Step direction invert, mask
$4=1 ; Invert step enable pin, boolean
$5=0 ; Invert limit pins, boolean/mask
$6=0 ; Invert probe pin, boolean
$10=2 ; Status report options, mask
$11=0.020 ; Junction deviation, millimeters
$12=0.002 ; Arc tolerance, millimeters
$13=0 ; Report in inches, boolean
$20=0 ; Soft limits enable, boolean
$21=0 ; Hard limits enable, boolean
$22=1 ; Homing cycle enable, boolean (Grbl) / mask (GrblHAL)
$23=7 ; Homing direction invert, mask
$24=100.000 ; Homing locate feed rate, mm/min
$25=1000.000 ; Homing search seek rate, mm/min
$26=250 ; Homing switch debounce delay, milliseconds
$27=5.000 ; Homing switch pull-off distance, millimeters
$30=255 ; Maximum spindle speed, RPM
$31=0 ; Minimum spindle speed, RPM
$32=0 ; Laser-mode enable, boolean
$100=39.990 ; X-axis steps per millimeter
$101=39.990 ; Y-axis steps per millimeter
$102=57.143 ; Z-axis steps per millimeter
$110=5000.000 ; X-axis maximum rate, mm/min
$111=5000.000 ; Y-axis maximum rate, mm/min
$112=5000.000 ; Z-axis maximum rate, mm/min
$120=500.000 ; X-axis acceleration, mm/sec^2
$121=500.000 ; Y-axis acceleration, mm/sec^2
$122=500.000 ; Z-axis acceleration, mm/sec^2
$130=390.000 ; X-axis maximum travel, millimeters
$131=390.000 ; Y-axis maximum travel, millimeters
$132=70.000 ; Z-axis maximum travel, millimeters
$I=acro55
