hi all, im having a few issues at high speed on my 30w co2 fiber laser, I die a test at 1000 speed with a line interval at 30 per inch and there is definitely an offset with the lines…
my question is, is it possible to do match the lines in way of an an offset function like in a ruida controller?
any help would be awesome guys as im getting blurred text etc and at the moment it unusable
You may need to adjust your Timing/Delay settings:
Did you import the markcfg7 file from your EZCad folder when you first setup your laser in LightBurn? If not, it’s worth trying that first - those settings can be imported into LightBurn, and you may not need to manually adjust them further yourself.
thanks for this, ive since found by lasering with a single direction on the laser instead of bi directional I get a nice neat engrave, so its definitely “A scan thing” I can always just opt for a single line scan but its a little slower than I would like…
unfortunately I’m Mac based so don’t have the luxury of getting anything from Ezcad, but Ill definaltey takea look at the video though,
Thanks again Jack, oops, ive searched so much about this that all the answers blended into one with the mention of Ezcrash cor files etc… sorry about that, I really appreciate you, Tyler and others taking the time to comment too, means a lot to know there’s good eggs out there willing to give a little bit of time to help…
I’ll give this a good going over today to see if I can rectify the issue, i’ll be sure let you know how I get on!
im not having a lot of luck with results after changing the settings, I also get double images when I use single scan and cross hatch, it seems there’s a misalignment and I just don’t know how to fix it…
