Offsetting a image to be cut is not cutting correctly
When we offset a leather image to be cut. It will cut shifted to the right. It gets worse if I copy and paste the same image to cut multiple at once. Am I doing something wrong. Sometimes if I only cut one at a time it will be better but not perfect. On lightburn the image looks perfectly outlined.
A picture or two, along with the *.lbrn2 file, will help us see what you’re seeing.
If it’s slanted, then you may have this issue:
If that’s not it, then it’s almost certainly a mechanical problem due to something loose in the X axis drive.
