Omni 1 5W laser and Lightburn
We are having trouble trying to engrave on a chuck some wine glasses, it is hit and miss, more miss. Flat glass is fine but the wine glass is like pulling teeth, can anyone give any advice
Hi David,
Can you share more details about the hits and misses?
Screenshots showing the entire LightBurn window including your rotary settings and, and if possible, pictures of the results on the wine glas on the chuck will help us help you.
Be aware glass is not just glass. There are different mixtures depending on the application. What worked on window or mirror glass may not even be close for goblet or shot glasses.
And yeah, do the pictures.
Which lens are you using? The depth of focus on a 5W uv is pretty damn small at approx ±0.2mm; The larger FoV lens will be a little more forgiving in the depth of focus at the cost of spot size. Wine glasses don’t tend to have tight tolerances, so you have to be very careful with fixturing and focus. If you have a dial test indicator, you could run a couple of rotations and see the deflection from the nominal zero. Also, if you are trying to engrave over a larger area, the shape is not conducive to focusing across the whole “height” of the curved glass surface.
Aaron, These are some of the results using 1 150mm lens
Reverse the Rotary direction in the Setup window here:
That should solve the main thing we see here.
Are you using a chuck, or a rotary motor?
Pressing the “Test” should rotate it a full 360 degrees, pause, then rotate back to the starting point.
