Omtech k40+ burns travel lines
I purchased a used on tech k40+ laser and it burns travel marks while cutting between the shapes I can’t figure out why been asking online everywhere not one single response and the laser stays on all the time it never shuts off or stop burning unless I turn the dial all the way down for the tube power it burns sitting in the home position
Did you enable laser mode in machine settings (Edit->Machine settings)?
Yes done tried that $32=1
Ah, just read your post again. If it always fires, no matter what you do software-wise, I guess it’s a hardware issue. You might check the cabling if something got loose during transport. I heard some reports about that. As next step, I’d try to flash the firmware again, to make sure the driving signals are ok.
