Hi all have very weak vertical lines on lettering min20% max30% speed 100 I have had to change controller and PC both were old and outdated on the old setup i used to run power at 25% and speed of 250 and results were perfect, check mirrors, laser condition, mechanical issues (I did change rail and bearing on X drive, all good). Is there something I’m missing in settings?
Did you adjust your current settings when you changed controller or have you ever?
If you synchronize the asked for pwm and it’s output, you can likely get closer to the OEM controllers settings.
as best as i could the old controller would only work with on old computer on XP, the computer died so got a new controller so had no settings to swap over.
Probably the Scanning Offset Adjustment:
Measure the offsets at 50, 100, 200, 300, and 500 mm/s on a material like paper that produces a sharp mark, fill in the table, and see if the situation improves.
A measuring magnifier will be helpful!
i have done that, not even .3 of a mm out.
on a 2mm wide vertical stroke if i look at it under microscope the right hand 1mm is darker than the left ?
That sounds about right, as the table for my machine tops out at 0.2 mm:
If your honeycomb is the same size as mine, then the vertical lines in the letters are under half a millimeter, so bidirectional scanning will require precise adjustment.
Are the speeds measured in the same units?
For example, if the old setup was 250 mm/s and the new setup is 100 inch/s, then the machine is attempting to run 25.4 times faster than before. The controller won’t let that happen, but the speed difference will definitely affect the results.
Upload the lbrn2 file for the text you showed so the hive mind can ponder it.
Also, upload a screenshot (not a cellphone picture) of the Machine Settings for the X and Y axes so we can check the speed & acceleration limits.
If it’s not loosing steps, then speed, likely, isn’t an issue.
It’s always nice to have the .lbrn2 file, if that’s available for us to check out.
- You don’t mention the scan angle, but unless it’s vertical, the smaller letters will have the scan angles fill. That might not be much by the looks of your letters. It also has to be multiples of 90 degrees or the Ruida can’t compute the operation.
- If you’re thinking it’s offset scan, then disabling bi-directional scan should eliminate the issue. The cost is twice the job time, but you can use it as a debugging tool
- It would be nice to be able to see both layer settings. You are running 15mm/s on the layer for your X axes, I can’t see min/max power, but running at or below the start speed, set within the controller, results in using only minimum power.
I didn’t put this as part of the list, but you should evaluate the interval you’re using. You have your image interval set to a 0.070mm (70 microns). The co2 with a 2" lens produces a spot size of about 200 microns. You are covering the same material 200/70 = 2.9 times over the same area.
You can’t have a 1" laser spot and do resolution below your, 1dpi, spot size. Resolution is the related to beam size and damage to the material. I have a rock, although the spot size is smaller than the damage to the material, whichever is largest will be the best resolution you can possibly get.
I think if you correct many of these issues, the result will be better.
Scan angle was zero, if i go 90 deg the problem becomes horizontal not vertical
I have tried disabling the bidirectional scan but did not help
the 15mm/s 80 power was for cutting out completed label on dual layer plastic, for “fill” i was experimenting with 44%power and speed 150, it would almost cut completely through on larger parts but the thin vertical lines hardly marked.
line interval was .1 but i experimented going to .07
If it’s disabled, the offset scan doesn’t change anything visible. I don’t know if offset scan is actually used if the bi-directional scan is disabled. If it was an offset scan issue it should go away with it being disabled.
It would help if you could supply us with the .lbrn2 file. Set it up as you were testing it.
That should help you debug it, if the image problem isn’t related to scan angle.
I was trying to determine what your minimum power settings were doing. You didn’t include them.
We wouldn’t have all of this back and forth if we could just look at your .lbrn2 file.
sorry, I don’t have that saved now, but I have tried on fill anything from 20 min-25max to 40min-40max and everything from 80-250mm/s but nothing cures the faint vertical line problem, more power and slowing just burns though in larger areas. it’s as if the laser doesn’t strike on like it used to for the thin lines. if i try on stainless steel with Cermark at 90 power and speed of 80 the vertical (thin) sections of lettering just wash off.
It is possible for the HV power supply + tube to take longer to start up than it used to, so the leading edges of features receive less energy.
Running some 5 mm squares on paper at various speeds & power levels would help track that down: if the leading edges are lighter and the length of the lighter area increases with speed, then the tube response time is slow.
This definitely looks like a fading power supply:
That’s from the 400 mm/s row. Assuming those are 5 mm squares, each scan line takes 12.5 ms.
The default setup has the bottom scan line running from left to right and the leftmost part just isn’t there: the laser isn’t turned for the first 6-ish ms.
The thin red lines highlight single scans across the block, all of which are light on a little more than half and dark on the remainder, which shows the laser isn’t starting up properly no matter which way it goes.
The width of the lighter section in the middle of the blocks (the “little more than half” section remaining unburned in either direction) increases with the scanning speed, which means the delay is roughly constant: more speed stretches the constant delay over a longer distance.
Based on that, I’d say the power supply is kaput. ![]()
i have a spare new power supply, i will install and give it a run. last time the power supply gave out it was on a long burn it would fade out, different issue.
having changed the power supply had laser on as soon as machine turned on, after playing with wiring had it working properly. issue has gone, as i said different to the last time a power supply failed (not able to do a long line, it would fade out). thank you all for your help. ![]()
And weird it coincided with the computer update. ![]()
If it’s any consolation, the HV supply in my machine failed hot right after a LightBurn update:
Always a puzzle. ![]()
