I’m new to this so I’m getting
?Idle|MPos:0.587,0.587,0.000|WPos:0.587,0.587,0.000|FS:0,0|Pn:P|WCO:0.000,0.000,0.000> on my console when connecting, as well as the laser turning off after burning on high power. any help??
This message seems fairly normal. It is likely a response from your firmware when your laser initially connects.
If your laser is turning off using high power it is likely that your power supply is failing. If you are able to burn at lower power and there is no issue that could indicate supply and demand issue.
