I’ve been using Lightburn since I got my Ortur LM2 20W last year. I just got a Neje Master2s 40W a couple of days ago and have it working in Lightburn. The problem seems to be only one layer will burn at a time. If there are 2 layers the first will burn then everything stops. If the first layer has the output turned off then the second layer will burn then it stops? The laptop I’m using I originally used with the Orur and had to set it up manually to find the Neje. I don’t know if this is a bug or if I need to reinstall Lightburn? Any help is appreciated.
