My design has 2 lines on it (in blue) which are open. On a previous occasion I did it with a different design and it was no problem. In this case LB removes that part of the design. I need that part to be included. What is there that I can do plse? I use Illustrator.
Change the layer type from fill to line for the 2 blue lines.
No, in LightBurn - In the Cuts window, the blue layer will be set to Fill. Change that to Line.
Oh, youâre using an older version from before the names were changed. Click âScanâ and change it to âCutâ to match the red layer.
Oh wow ok thx. I just noticed that just now and thought it should be changed anyway. Where do I get the now version?
Click Help > Check for Updates and follow the prompts.
You can see whatâs changed or been added with each release here:
Thank you very much.
Is there a video specifically about the use of Library?
I havenât been able to figure it out.
The material library, I assume?
There isnât a video that shows the usage from scratch, though thatâs a good idea. This thread has some discussion of how to use it, as well as links to the documentation and a video:
Thank you for your time. Iâve spent 2 days trying to solve this myself and now the work can continue. Thx for this, I will go look through that tread. If I can use the Library it will save me going outside and switching the machine on just to be able to do quotations.
Donât click âvideo tutorialâ, click âHow to use the material libraryâ - that will bring you to the discussion on it, which includes the discussion of the video link not working.
