I have an OpenBuilds Blackbox X32 controller I was using in a home built CNC Plasma cutter
I want to use this now with a Diade Lase with Lightburn software
Is it comaptible
Any help with the connections
Download the Lightburn Trial and see if it works. You have a month to figure it out.
USB, using the CH340 driver, or Ethernet, which is recommended. If your machine uses RS-232 or RJ-45, then there will more work involved.
Hook everything up, do some testing and then come back with specific questions. That will be the fastest path to success. And you will likely get better answers.
The blackbox should be fully compatible - you’ll need to do your setup for the new laser source, compared to the prior plasma source
Thank you both for your reply.
Is there any recomended controllers for a home built unit that are compatible to LightBurn.
Happy to buy another controller if it is going to be easier to set up.
The black box is a great controller - use it if you can.
But not easier to hook up. ![]()
Hi Mikey
what are the issues you see with hooking the black box up.
I have connected a plsma cutter to it in the past
Any help would be great
I was talking about the “any recommended controllers” you were asking about.
If your Black Box controlled a plasma, I think you are 95% done. It already has the ability to turn off during traversal moves. That just leaves managing the power to the laser.
12vdc or 24vdc for power.
PWM to control the on-off time for a 0% to 100% power output control.
Something rarely mentioned is that a diode laser is not just on or off. It is actually clocked at something like a 1.5KHz rate.
I hope this is enough to get you started. As @Colin said, there should be a setup process for laser control. There are others that use the Black Box control on laser machines. Search the Forum for Black Box and you might be able to Message others with this control.
Hi Again
I think I have the wiring for the laser and PWM under controll
How can I turn the air pump on
Do I have to do this manually
Ian R
