Bertus
(oud)
December 18, 2020, 3:09pm
1
Hello
Lightburn is used.
machine belongs to someone else
how can these openings be caused.
speed is 500
cnc3018
power 20
Rick
(Technical Evangelist)
December 18, 2020, 6:42pm
2
Bertus:
speed is 500
500 what? 500 is not a speed. 500 light years a second, 500 KPH or 500 mm/min are speeds as they provide all required data points to show speed as a distance traveled calculated over some time interval.
What version of GRBL do you use? GRBL-LPC has parameters that let you tune the lower end of the power ramp so you can “pull it up” to where a high power tube ionizes. I’m not certain 1.1f has this - it wasn’t really meant for high power lasers. The alternative would be to use the GRBL-M3 driver, which doesn’t use power ramping.
I want to reorganize my GRBL GCode generator to allow these to be used by the same device, but the way it’s set up right now, the M4 based generator assumes “laser mo…
system
(system)
Closed
January 18, 2021, 8:54am
4
