Optimise curves / objects with shared edges / borders
A lot of my designs have objects that have a lot of shared edges that don’t need to be cut more than once, but will because they are described by two or more objects.
I could manually and tediously edit all of these shapes so that a shared edge only occurs once and removed from the other objects, but this is a huge PITA.
Is there anything in Lightburn to do this automatically? Thanks.
… It shouldn’t be a problem can you show an example? (lbrn2)
It’s not a problem it’s just wasteful cutting the same path twice.
Imagine a design with a circle that has a thick outline. Both are separate shapes. The common edge would be cut twice.
By pure chance or by divine guidance I found a setting anyway by chance!!
SOLVED!
