I’m trying to get rid of this movement across the part- it seems like the path should go to the nearest corner. I tried several optimization settings that looked possible but none changed anything for the better.
If you’re unable to get the specific movement pattern you wish by adjusting the Optimization Settings, you can manually set the Cut Order Priority in Shape Properties.
