Hi there, is there any way to get ride off all those moves from left to right ? Just tell the laser to move from point to point.
I loose so much time!
Thanks
In optimization settings, you can try setting “Reduce Travel Moves”, and turning on the “Optimize Cut Path” option.
If your optimization settings are enabled, make sure the “reduce direction changes” toggle is off. It currently does not take distance into account, and can make poor choices as a result (fixed in the next release).
