when i hit start to engrave lightburn stops responding when the pop up window says optimizing cut plan and progress bar at 80%
Can you share the LightBurn project file you’re seeing this with? If you’d rather not share it here you can send it to support@lightburnsoftware.com, and link this thread in your email.
If there are no optimizations you require for this job, you can try turning off ‘Optimize Cut Path’ in the Laser window.
