Orientation changes drawing item size
I have a cut out that is one size on the drawing pallet, but when cut is another size horizontal, yet another size when turned vertical. It also tries to draw outside the top of the cutting pallet. I am sure that i have a setting somewhere wrong, but can not find it. ? Happy to provide pics and screen shots.
Any ideas or help would be appreciated.
What does your preview show?
Can you upload the file here?
OK, Preview shows normal. Lightburn also hits both the rail at the top and bottom of the Y axis when it should stop at around 5MM and 400MM, the working area ix 460x460. Also just cut a prefect circle 15mm square, got back an oval 14x17. cant be more precise on the size as the caliper is small and I have a hard time readding the caliper.
It looks like you have ‘Rotary Mode’ enabled, but are engraving on a flat surface. Try toggling Rotary Mode off.
Thank You Sooo Much. That was it. :grinning: :grinning: :grinning:
