I’m new using Lightburn with an xTool D1. The homing is good at the back left, when I give it move commands, it moves to where it’s supposed to go. The problem is that I put a box and some text in the center of Lightburn and when I go to start, the laser head moves towards the back left instead of the center. I’ve looked at the settings but don’t see anything that looks out of place. Any suggestions?
Where did you configure origin in Edit->Device Settings? Did you use the xTool provided .lbdev file to configure your laser? If not, I suggest you do so.
Thanks for the suggestion.
I’ve upgraded the firmware and have tried xTool_D1.lbdev AND xTool-D1-V2.lbdev, (I removed the first one and relaunched Lightburn before installing the second). It’s driving me insane that I can move the laserhead manually, set up saved positions…but when I set anything in the center of the work area and hit frame, it always goes back to the left rear corner, which I assume, is the home position.
OK…problem is fixed. Seems that I overlooked a small switch on the xTool for updating the firmware. Everything is working ok…thanks for taking the time to provide feedback.
