I recently purchased the Orion 60w upgraded laser with Lightburn. I ran the test project that comes with the laser and it printed. I then made a quick Lightburn project, saved it to the U drive supplied by Orion and when I put it in the laser drive, it showed no files. I then saved the test file to the U drive and the machine found that file but not the lightburn file. I also did the same with another USB drive. I am pretty sure it is a Ruida controller. What am I doing wrong?
If you are going to transfer using a usb drive, you need to save as an RD file on the drive.
