I changed some machine settings (like auto home on start up, soft limits off, homing cycle off) to use xtool rotary for engraving mugs. After changing settings back to original settings (I think i did it right) i try to engrave from middle of work area (framing beforehand). upon hitting the Start to engrave, the laser heads directly to right rear corner and crashes. any suggestions?
The easiest fix is likely to just reset your laser to defaults. That’s a safe operation on Ortur lasers.
Issue this in Console:
$RST=*
Then power cycle and retest.
If you want to get to the bottom of what exactly caused it can you run these things in Console:
$I
Also, make sure you’re not still in Rotary mode in LightBurn.
I will try these as soon as i can and will let you know if it helps. Thank you for your response!
