I am trying to set up my Ortur Laser Master 1. I am completely new to this and have added it to my workshop to engrave names, messages, small pictures, etc., on my woodworking projects. I hoped this was going to be a simple plug and play process, apparently not.
I have been getting the following message when I turn on my laser;
Waiting for connection…
[AUTHOR: ORTUR]
[MODEL: Ortur Laser Master]
[OLF: 140]
[DATE:13:35:40 - Dec 31 2020]
[VER:1.1h.20190903:]
[OPT:VNZHI,99,254]
Target buffer size found
ok
[MSG:No Power Supply]
Homing
ALARM:9
Homing fail. Could not find limit switch within search distance. Defined as 1.5 * max_travel on search and 5 * pulloff on locate phases.
ok
Ortur Laser Master Ready!
OLF 140.
Grbl 1.1h [’$’ for help]
[MSG:’$H’|’$X’ to unlock]
[MSG:Caution: Unlocked]
ok
Starting stream
ALARM:2
G-code motion target exceeds machine travel. Machine position safely retained. Alarm may be unlocked. (Right-click the ‘Devices’ button to reset the connection)
On or near line 2:
Stream completed in 0:00
[MSG:Reset to continue]
After looking again I noticed the, MSG:No Power Supply.
I am hoping this doesn’t mean my power source for the laser is bad. I have checked all the connections and they appear to be properly connected.
Any assistance is appreciated,
Thank you
