Hi everyone , hope someone can help please.
I followed the hobby guys information video on how to use the ortor Rotary. Worked fine . The video was very informative and well done . Problem i have is the laser will not go back to normal use . Ortor master 2…
I have followed the information to return it yo normal use . But all it will do is Home , and thats it . I keep getting the error message Alarm maybe unlocked please connect… i cant fine the alarm to connect in the devices. Im lost . Should i delete program. And reload. Please help
There is a known issue with the rotary / homing setting for your Ortur model that could be causing the issue you’re seeing.
In your Console window, enter $22=43, then restart your laser. That should correct the issue, but unless you update your Ortur’s firmware, you’ll need to enter that after each use of your rotary.
You can find up to date firmware and instructions here:
