I just upgraded from the Ortur laser master 3 10w to the 20W. I have it installed, but now i cannot get it to do anything else. Do i need to adjust settings in lightburn?
As in what?
I messed with it a little. It will only move side to side.
Replacing laser should not affect its movement. I suspect the problem is in the size difference and some kind of interference.
What happens when you try and home it?
It moves to the left but will not move up or down.
With machine off can you physically move it in all directions?
Yes I can.
I am a dummy!! I had the switch on YRR instead of the Y-motor!
