I have an Ortur Laser Master 2 Pro, and using Lightburn, when I hit START to burn a project directy, about 20% of the time, the laser moves to the first pixel, turns the laser on and then fails to move. I have to hit stop quickly, re-home, re-frame, and try again, usually works the second time, but often I now have a hole were I wanted an engraving. Does not seem to happen if I save G-code and run then G-code. @OrturTech
Questions if i may
In console Type $i and press enter
Post output
This project issues the same result IF in absolute coordenates, or just in current position?
Can you add also a image of the project showing the settings?
