Ortur LM2 Pro stops engraving
I have an Ortur LM2 Pro that just keeps stopping while doing an engrave. It stops at the exact same spot every time. I’ve tried 2 different SVG files. It works fine with some projects, but not others. I am running LB 2.2. I have tried it using the laptop hooked up to it and I’ve also tried with the Raspberry PI. It still stops in the exact same spot. When I look at the console, it is the same G-code that, so I know it is the same line.
Without knowing anything about the design, the G-Code, or the specific error, it’s difficult to be specific, but that sort of problem crops up when the Device Type doesn’t match the actual laser.
I think LM2 controllers speak plain GRBL, so make sure it’s configured for GRBL rather than any of the more specific flavors.
If that’s not it, more details will be exceedingly helpful.
I have been using LB with this laser for years without issue. But most of my time is spent cutting and not engraving. I have done engraving, but it is usually small jobs with just some text. This job is an SVG file that is about 4 inches tall and 3 inches wide. I have had cutting jobs that are like an hour long and using almost all of the size capacity of the machine. This tells me there is nothing physically wrong with the machine. The G-code sender (laptop or PI) sends the code, but the controller never says received in the terminal. The fact that it stops at the exact same spot and line every time, makes me think it could be an issue with LB’s G-code generation. I am hesitant on uploading the SVG since it is a paid SVG.
Llightburn’s code generation depends on the SVG design.
Rather than posting the SVG, send it to Support@LightburnSoftware.com and include a link to this Thread.
Yeah, I am thinking of converting it to a PNG to engrave that way. From what I understand, is that an SVG could cause a lot of micro moves that could overwhelm the controller.
Did you detect and delete duplicates before the burn? I have seen really dirty (as in huge number of open shapes and duplicates) in prepared svg files. AI created svg are especially prone.
Also, I suggest that you check your preview for overscan hitting the edge of the workspace.
Yes, detect and delete duplicates found nothing. I checked the preview; there was nothing showed any issues. I opened the SVG file in Inkspace too. I didn’t see anything like I’ve seen with bad SVGs. I also tried the DXF that was provided. Same issues.
On your preview, do you have SHOW TRAVERSAL MOVES enabled? The red blurry outline shows the laser position for overscan movement. The faster the move speed is set, the larger the area in needed for acceleration and deceleration.
Another idea for you to try… for fill issues.
Change your scan angle from 00 to 180 degrees - does the stoppage still occur at the same place in the design?
While not optimal, I sometimes use 90 degree scan angle as well. That puts the major axis on the Y vs on X axis. The trade off is more mass to move, and that will show as lower tolerance for over optimistic speed settings.
I believe this was it. I have never had to worry about that before. But again, most everything I’ve done is cutting at slow speeds or engraving small areas. I had the image at the edge of the workspace. I just moved it over a few and it seems to be fine now. Once I test this more, I will confirm.
That was indeed it. The traversal moves were out of bounds on the preview. Such a silly thing that could have easily be caught and a dialog popped up about it. I chased this for 2 days and the software already knew this. This should be a feature of the software.
Thanks to all for providing assistance.
Perhaps one of these appeared in the Console Window where you saw the G-Code:
No, not at all. If it had, that would have helped. No, it just stopped with no errors. It shows that it sent the g-code, but the controller never responded with a received response. Still, if LightBurn already knows that it is out of bounds before it starts, it should warn you. MillMage does a lot of warning of these types of issues. :slight_smile:
I agree, that’s annoying, especially when it happens toward the end of a long job.
This popup dialog does exist :slight_smile:
But it only appears when:
That’s good to know. One thing to note, I don’t use LightBurn to control the laser. I generate the G-code and send it to a Raspberry PI that controls it. But even then, it should be able to check when generating the G-code. I do hope that this post helps others if they run into a similar situation. The new laser I am building will be more robust.
If the G-Code uses a User Origin or Current Position defined on the laser controller, then LightBurn has no way of knowing where the machine boundaries are in relation to that starting point and can’t indicate an error due to that (unknown) position.
I almost missed this detail. I was not aware the GRBL controller could have a different Origin than what Lightburn knows about.
No matter, it has been said 1000 times that the Preview is an extremely important tool. That is my last step before generating any output. If I do not turn on Show traversal moves, that is my fault, not Lightburn’s.
I can say with certainty that I won’t have this particular issue again knowing what I know now.
Hahaha! Don’t try carving that in granite.
Okay, let me rephrase that, I can guarantee that the next time this happens, I won’t lose 2 days of work and spend several hours trying to find a fix…hopefully
Just an FYI, I had all of that on when I tried it directly from my laptop which was controlling the machine with LightBurn and no warning dialog like that popped up.
