# Ortur master 2 framing wont work
**URL:** <https://forum.lightburnsoftware.com/t/ortur-master-2-framing-wont-work/17541>\
**Tags:** grbl\
**Created:** [June 13, 2020, 11:05pm UTC](https://forum.lightburnsoftware.com/t/ortur-master-2-framing-wont-work/17541 "2020-06-13T23:05:07Z")\
**Showing post:** 2
**Author:** ![LightBurn](https://forum.lightburnsoftware.com/user_avatar/forum.lightburnsoftware.com/lightburn/32/75577_2.png) [@LightBurn](https://forum.lightburnsoftware.com/u/LightBurn)\
**Post date:** [June 14, 2020, 4:02am UTC](https://forum.lightburnsoftware.com/t/ortur-master-2-framing-wont-work/17541/2 "2020-06-14T04:02:54Z")
> [@How do I turn on my diode at low power to focus it or frame a job?](https://forum.lightburnsoftware.com/t/how-do-i-turn-on-my-diode-at-low-power-to-focus-it-or-frame-a-job/10520):
> Diode lasers often don’t have a red-dot pointer like CO2 lasers do, so it is often useful to enable them at low power for focusing or framing. (Please do NOT do this if you have a CO2 laser, as the beam is invisible and this could blind you or start a fire) In LightBurn, go to Edit \> Device Settings, or click here: [image] Turn on the ‘Enable Laser Fire Button’ switch (make it green): Quit LightBurn and re-run it. You will now have two new controls in the Move window. A …
You need to hold the Shift key when you frame to make it fire. Have you enabled the fire button _and_ entered a percentage for firing in the Move window?
_[View the full topic](https://forum.lightburnsoftware.com/t/ortur-master-2-framing-wont-work/17541)._
