I’ve found some posts by people having problems updating some older, 1.8x versions, which sound like the same behavior I’m seeing. The few that had solutions, didn’t work for me, and the rest just simply went silent with no solution posted.
I’ve had no luck with Ortur tech support. They insisted that I must be doing it wrong, so at their request, I sent them a video of me doing the upgrade, and then I never heard back.
What’s happening is I get it into firmware update mode, it shows up as a removable device on my PC, I copy the bin file over and the Ortur immediately disconnects and shuts down. When I bring it back up and fire up Lightburn, it still shows version 190. I do the $RST=* command to factory reset, still 190.
I’ve verified several times that I’m downloading the correct firmware, and redownloaded it just in case something is going wonky there. I’ve tried different USB cables, different ports on my PC, unplugging everything else from the Ortur, letting it sit with no power before the upgrade, Debian 12 and Win 11 Pro. Always the same behavior every time.
The only potential solution I haven’t tried, is to spin up a Win98 VM and do the upgrade from there. One person apparently had success with that.
I have tried it probably 20 times at this point. I’m positive that I’m doing it right. Here is the Google Drive link to the video, if anyone would like to see if I am in fact messing up the procedure somewhere.
Thanks in advance for any advice.
Edit: added Google Drive link.
