Ortur rotary settings
Is there instructions showing settings in lightburn for the Ortur rotary. Also how and when to change settings.
I look forward to hearing from you
I have the Ortur lm2 pro with the yrr rotary.
This might be worth a read
Setup-Ortur-YRR - Copy.txt (936.3 KB)
Change the .txt to .pdf
Hi
Thanks for reply, would not let me view when I downloaded it.
Did you rename it by deleting the extension .txt, replacing it with .pdf ?
How do I change it to .pdf , does not give me option to do that.
I just right click the file then select ‘rename’ and then change the extension
Trying to view it on my ipad won’t let me rename it. I will have to look at it on my pc.
Louisiana hobby guy has a YouTube video on how to set up the rotary. It’s well worth watching. Sorry I don’t have a link.
Hi
I have seen this video and seems straightforward. My question is once you have set it up and done your engraving , do you have to follow a sequence to set it back to your default laser settings.
Do you have to re set default settings before you turn laser off.
