Ortur Master2 20 watt. I can’t change the engraving speed. The Iaser head speed doesn’t change speed at different speed settings. If I set the engraving speed to 3000 in/min it will run that same speed even if I set the speed at 500 in/mn.
The maximum speed on the OM2 laser is around 1000 in/min. So you’re exceeding that with 3000 in/min and approaching that with 500 in/min. Does the perceived speed insensitivity scale all the way down to something like 50 in/min?
