Ortur YRC1.0 jak nastavit
Hello, can anyone advise? A colleague already dealt with it here, but he didn’t get around to it. I had the same problem as you. In the case of using a frame, the laser precisely delimits the image. But when using manual guidance to place the image, a completely different position is found. I don’t know what to try anymore. I have the parameters set correctly. mm for rotation also correctly, because during the test the chuck turns exactly round. I’m pretty desperate already. Thanks for any advice.
Here is a link to a video where you can see what is happening. I have a Neje3max machine.
