So if im correct i need to find out and set the mm per rotation and the roller diameter only once. but i don’t know these, also i did not find it online anywhere for the ortur yrr rotary. does anyone know the correct values? if not whats the easiest way to find out?
Enter the roller diameter first. Then run a job of known size on the rotary (like a 20x20mm square). Measure the result, and adjust the ‘mm per rotation’ value based on the result, like this:
New value = Old value x Requested size / Actual result size
For example, if the result is only 10mm around, you’d double the ‘mm per rotation’ value (New = 360 x 20 / 10). If the result was 32mm, you’d do New = 360 x 20 / 32.
