I started using LightBurn about a month ago and I am running into problems I have Ortur OLM2 S2 LU2-2 and when I do a larger project say 204 height to 98 width I can engrave it fine but to cut the project out it will cut the laser off and still run the project stopping at the same place each time. If I move the project slightly to a different location I will get an out of bounds message and if I want to continue I always click no and try to move the project. Most times I can find a location after a frustrating half an hour or more of moving the project. It will cut fine and then after setting up a second time with not changing a thing it will stop where it did before. Please help!!! So frustrated what am I doing wrong?!
What is the “start from” Type Current position?
Can you post a full screenshot of your lightburn project window?
I have tried each one of the absolute, origin and current with it still running into the issue. I will get you a picture of the project tomorrow I have become so frustrated and shut everything down for the night my apologies.
First thing i woudl do is
a) Absolute coordenates
b) place project X10 Y10 (as in near the homing corner but a bit distance)
c) run the project at low power 1%, see if it finishes
then you can stablish is something about the coordenate system and not a hardware/software issue
Thank you so much I will try that in the morning.
