When I try and burn with lightburn. it tells me I’m out of bounds. But I know my project isn’t. I want to buy the software but I can’t get it to work…Thank You.
What is your ‘Start From’ setting? If it’s not ‘Absolute Coords’, it should be - read here to understand why: https://lightburnsoftware.github.io/NewDocs/CoordinatesOrigin.html
If it’s already set to that, type $# into the console and press enter, then copy the text it emits back here so we can see.
Mine tells me it’s out of bounds at the start of every cut but i go ahead anyway as i have had no problems. The software is very good and even with the warning box i really like it.
Lee - Your machine doesn’t have limit switches, most likely, so the software has no idea where you are (neither does your machine). You can turn off the warning in the device settings.
