Shout out to Sean Murray, this works well. Black spray paint on acrylic.
80w, speed 100mms, 18% on top 12% on bottom.200 dpi.
How do you set different power levels for top and bottom?
Min / Max settings don’t do anything for dithering - you’re getting 18% for the entire image, because dithering is just on/off.
With that method, what does the result look like if it’s back lit, rather than edge lit?
Would probably work nicely on glass as well, I’ll do a test as soon as I moved my laser to the workshop.
Had no idea, which image setting gives most detail?
Probably Jarvis or plain dither.
What type/brand of paint did you use?
looks good - did you wash the paint off ?
