Partial import of dxf
I want to import a dxf file into Lightburn but it isn’t happening correctly. The dxf started as a dwg in Autocad 3d Map which I saved as dxf. Then I try importing that into LB and I see only bits of it.
This link has various files:
  • png which is a screenshot of the dxf in Autocad
  • dwg file
  • dxf file
LightBurn does not deal with 3D solids, so that would explain it. The official AutoCad spec documents them like this;
1 Proprietary data (multiple lines < 255 characters each)
3 Additional lines of proprietary data
So, that’s helpful. :slight_smile:
I did a FLATSHOT in Autocad then exported that to dxf, then imported the dxf to LB and that looks good.
Thanks!
