# Pass-through modifications?
**URL:** <https://forum.lightburnsoftware.com/t/pass-through-modifications/82755>\
**Created:** [November 24, 2022, 10:56pm UTC](https://forum.lightburnsoftware.com/t/pass-through-modifications/82755 "2022-11-24T22:56:14Z")\
**Showing post:** 2
**Post date:** [November 24, 2022, 11:03pm UTC](https://forum.lightburnsoftware.com/t/pass-through-modifications/82755/2 "2022-11-24T23:03:06Z")
If you are referring to the Ruida, it doesn’t do so well with anything that is not 90 deg increments…
> [@Ruida 6445 max speed & scan angle 45deg](https://forum.lightburnsoftware.com/t/ruida-6445-max-speed-scan-angle-45deg/8247/2):
> Ruida controllers do not support rastering anything other than 0, 90, 180, and 270 optimally in hardware. Other scan angles will work, but are just done using standard cutting moves, and the controller will not be able to process them as quickly.
How does this relate to pass through … physical or layer setting?
_[View the full topic](https://forum.lightburnsoftware.com/t/pass-through-modifications/82755)._
