Paste brings old projects into new windows
In new job window I downloaded an image and wanted to use paste to take out the background but when I do it brings a previous job into the window, so I delete it and yet every time I use paste it comes right back, would love to delete this permanently so I can use the paste feature. Thanks
Maybe you should clean Windows clipboard:4 Methods to Clear Clipboard in Windows 10
Thanks for the info, I looked into windows and it said that my clipboard was empty so I don’t think that’s the problem , what I ended up doing is now my paste in LightBurn doesn’t work at all no matter what new project I do I have no idea what I’ve done, I’m definitely new at this and this is frustrating, I’m hoping someone else has had this problem. Thanks
Do you have use system clipboard enabled in settings?
Yes, thank you I do, I’m beginning to think there might be a glitch in my computer, because just checking my computer clipboard has since made my paste not work it just turned gray even when I click on an object
Paste will be gray if there is nothing on the clipboard. You have to copy something in order to paste.
I think you may be misunderstanding how cut / copy / paste function. Copy makes a copy of whatever you have highlighted and places it on the clipboard, then you use paste to place what is on the clipboard into your document, image, etc. Cut is the same as copy only it actually removes the highlighted item from it’s current location and places it on the clipboard.
You can remove the background of an image in some software or online.
Here is a site: https://www.remove.bg/
Ok, I’m getting this now, didn’t copy first, I’m definitely a rookie to this lol, very much appreciate the help and information thank you both
Good, I’m glad you figured that part out. There is no shame in not knowing, only in being afraid to ask.
