So I’m curious if possible, can I pause a job in process AND make a change to the project, then continue from that point? I know I can alter power and speed on the one tab although I do not like them interacting with each other. But let’s say I see an error that the process has not yet reached. I wish to fix it and continue rather than wasting material by having to start over. Thoughts?
No, that’s not possible. Once the project is started, the GCode is generated and queued for the laser. You can even clear the workspace and the job will still be finished.
If you often need to modify your designs, put them onto different layers or use “cut selected graphics only” to do your project in smaller chunks.
Ok, thank you Sir.
